查看: 1569|回复: 0
购车求助
2 分
发表于 2011-5-12 09:17 |只看该作者 |倒序浏览
现在有四种选择,不知道大家推荐俺哪一种,先行谢过大家
1. 2010 Scattante R-570 Road Bike ($899)
http://www.performancebike.com/bikes/Product_10052_10551_109123
BOTTOM BRACKET: FSA Mega EXO
PEDALS: Wellgo Clipless Road
BRAKES: Tektro R520, dual pivot
REAR DERAILLEUR: New Shimano 105
CASSETTE: New Shimano 105, CS-5700, 10-speed, 12-25T
CHAIN: KMC DX10 SC, 1/2"x11/128",116L
CRANKSET: FSA Gossamer, 50/39/30T chainrings
FORK: SL3 1 1/8" CroMo steerer, carbon legs
FRAME: XRL double-butted Aluminum, double water bottle mounts,
replaceable rear derailleur hanger
FRONT DERAILLEUR: New Shimano 105, FD-5700
GRIPS/TAPE: Velo Gel
HANDLEBAR: Alloy, 31.8mm Center, Width: 400mm(48cm), 420mm(51/54cm),
440mm(57/60cm)
HEADSET: Cane Creek 1 1/8" integrated, alloy top cap
LEVERS: New Shimano 105 ST-5700
RACK MOUNTS: No
SADDLE: Prologo Scratch Pro
SEATPOST: Alloy, 27.2 X 300mm
SHIFTERS: New Shimano 105 ST-5700
STEM: Alloy, ID: 28.6mm, -5 degree, Bar bore: 31.8mm, Length: 90mm(
48cm), 100mm(51cm), 110mm(54cm), 120mm(57/60cm)
TIRES: Vittoria Zaffiro, 700c x 23
WHEELSET: Alex ALX270, 700C, Front: 20H radial, Rear :24H, Stainless
Steel spokes
2. 2011 Windsor Fens(white) $749.95 (http://bikesdirect.com/products/windsor/fens_xi.htm)
Frame: Engineered, Precision welded Heat treated aluminum main tubes and
rear stays, 2x H2O bosses, replaceable rear derailleur hanger
Fork: Kinesis carbon fiber legs with 1.125 inch steerer tube
Crankset: FSA Vero Aluminum Alloy arms, Triple 50/39/30T Black Finish
Bottom Bracket: Sealed Cartridge Bearing ST
Pedals: FREE: Road Clipless compatible with two bolt/spd sole shoes (not
"spd-sl")
Front Derailleur: 2011 Shimano 105 / 5700 for triple 30 speed
Rear Derailleur: 2011 Shimano 105 / 5700 for triple 30 speed
Shifters: 2011 Shimano 105 Integrated STI 10 Speed, (30 total gears,
ST5700)
Cassette/Freewheel: 2011 Shimano 105 HG5700 10 Speed Cassette 12-25T
Chain: 2011 Shimano CN5700 HG 10 Speed
Hubs: Formula Aluminum for 10 speed (30 gears total)
Spokes: Stainless Steel, Radial front pattern
Rims: Alex DA22 Aluminum Wheelset with machined brake track
Tires: Michelin Dynamic 700x23 high pressure road tires, presta valve
tubes
Brakes: Tektro R530 BlackChrome DualPull aluminum calipers
Brake Levers: Shimano 105 (integrated with shifters) ST5700
Headset: Threadless Sealed Ball Bearing Aheadset 1.125"
Handlebar: Ritchey Comp 6061 Butted Aluminum Biomax Ergo bend
Stem: Ritchey Comp Threadless Aluminum 1.125 steerer, 31.8mm clamp
Tape/Grip: Black cork
Saddle: Racing with accent panels
Seat Post: FSA Team Issue Carbonwrap, 27.2mm
3. 2011 Gravity Comp30 $799.95 (http://bikesdirect.com/products/gravity/comp30_silver.htm
Frame: Gravity RSeries Aluminum, Engineered Hydroformed Top tube, Bi-Oval
downtube, S-Bend seatstays, 2xH2O mounts, replaceable rear derailleur
hanger
Fork: Kinesis Aero-profile, Carbon Fiber Straightblade, 1.125 inch
steerer
Crankset: FSA Omega Aluminum arms, 50/39/30T (130BCD)
Bottom Bracket: MegaEXO External Bearing Sealed BB4000
Pedals: 9/16th axle, Platform pedals included (does NOT come with
toeclips/straps)
Front Derailleur: SHIMANO 105 ST-5700 for 10 Speed
Rear Derailleur: SHIMANO 105 for 10 Speed (30 gears total)
Shifters: SHIMANO 105 ST-5700 for 10 Speed (30 gears total)
Cassette/Freewheel: Shimano 5700 Cassette 11-25T for 10 Speed (30 gears
total)
Chain: Shimano for 10 Speed
Hubs: Vuelta aluminum, Black finish with Quick Release
Spokes: Bladed Stainless Steel
Rims: Vuelta ZeroLite Comp, Double Wall aluminum with machined brake
track
Tires: 700x23C BLACK F/V MICHELIN DYNAMIC or CONTINENTAL ULTRA SPORT, (
cannot choose which tires), presta valve tubes
Brakes: Tektro R570 Dual Pivot, Aluminum Black finish
Brake Levers: SHIMANO 105 ST-5700
Handlebar: Aluminum alloy black, 31.8mm 400MM(43-49CM), 420MM(50-54CM),
440MM(55-60CM)
Stem / Headset: Aluminum alloy threadless, 1.125", 31.8mm clamp, EXT:90MM
(43~46.5)/100MM(50~53.5)/110MM(53.5~58.5), Cane Creek VP-A71 Labyrinth
Sealed, Cage Ball Bearing
Saddle: Gravity Road with comfort groove
Seat Post: Aluminum alloy Micro Adjust 27.2mm
Seat Clamp: Machined Aluminum Alloy with bolt
4. 2011 Gravity Pro30 $899.95 (http://bikesdirect.com/products/gravity/pro30_gray.htm )
hanger
steerer
Crankset: FSA Gossamer Aluminum arms, 50/39/30T (130BCD)
Bottom Bracket: FSA MegaEXO External Bearing Sealed BB8000/6000
toeclips/straps)
Front Derailleur: SHIMANO Ultegra ST-6700 for 10 Speed
Rear Derailleur: SHIMANO Ultegra for 10 Speed (30 gears total)
Shifters: SHIMANO Ultegra ST-6700 for 10 Speed (30 gears total)
total)
Hubs: Vuelta PRO aluminum, Black finish with Quick Release, Precision
Bearings
Rims: Vuelta ZeroLite PRO, Double Wall aluminum with machined brake track
Brake Levers: SHIMANO Ultegra ST-6700
Stem / Headset: Aluminum alloy threadless, 1.125", 31.8mm clamp Cane
Creek VP-A71 Labyrinth Sealed, Cage Ball Bearing
因为在美国佬这里求学,都是英文的信息,不好意思,这厢有礼了
[此帖子已被 斯塔尼 在 2011-5-13 14:07:10 编辑过]
GMT+8, 2026-5-23 19:54 , Processed in 0.091474 second(s), 31 queries .
