查看: 1427|回复: 1
foobar2000不建议使用ASIO
104 分
发表于 2014-6-19 23:01 |只看该作者 |倒序浏览
ASIO support
By: Peter
Provides ASIO output support.
Version 2.1.2 highlights:
* Fixed phase inversion with 32-bit output.
Please note that this component is meant for systems where ASIO is the only available output method. It is highly recommended to use the default output modes instead of ASIO. Contrary to popular "audiophile" claims, there are NO benefits from using ASIO as far as music playback quality is concerned, while bugs in ASIO drivers may severely degrade the performance.
我简要翻译下:
此模块是为此特殊情况所准备:操作系统中仅有ASIO驱动可用时。我们强烈建议用默认的输出方式,而不用ASIO。与发烧友所宣称刚好相反,ASIO对音乐的回放质量不仅没有任何益处,而且ASIO驱动所带的BUG还会严重的降低回放性能。
原文地址:http://www.foobar2000.org/components/view/foo_out_asio
[此帖子已被 姜宇熵 在 2014-6-19 23:04:11 编辑过]
125 分
69 小时
发表于 2014-6-28 00:21 |只看该作者
哦,是吗,没注意过哦,反正我也听不出来什么
GMT+8, 2026-7-7 02:19 , Processed in 0.094895 second(s), 25 queries .
