查看: 2428|回复: 7
[原创]LspCAD V6.0(2004-11-02)版破解
发表于 2004-11-4 15:51 |只看该作者 |倒序浏览
[watermark]
LspCAD20V6_1099554693.rar
14.49 KB, 下载次数: 227
发表于 2004-11-4 16:16 |只看该作者
真快呀。昨天抱歉,刚要传文件就切断信号了。有时间msn联系,我再传
高级会员
749 分
24 小时
发表于 2004-11-4 19:55 |只看该作者
更新版解不了
22.55 KB, 下载次数: 223
发表于 2004-11-4 20:32 |只看该作者
从www.ijdata.com重下一个就行
发表于 2004-11-6 12:55 |只看该作者
官方网站版本又升级了,Cr软件是否要再次升级?
History list LspCAD 6
LspCAD 6.00 (2004-11-04)
+ Rare problem with cascaded wire components fixed
+ LSPCAD6WORKINGDIR was not working properly if ';\';
  character at the end
LspCAD 6.00 (2004-11-02)
+ Program crash bug related to the use of baffle components fixed.
+ Dropdown list for range setting changed to readonly
+ Extra transfer function offset/enable not saved in project file
+ Scrolling problem and fixed first row in TS parameter list fixed
+ LSPCAD6WORKINGDIR environment variable makes it possible to have
  another directory than the LspCAD folder as default working directory
+ Baffle diffraction setting for radiation component not saved
LspCAD 6.00 (2004-10-26)
+ Special Win98 SE patch needed to make sure that
  Settings/Optimizer/Emulator dialog can always be opened.
+ Diffraction analysis error fixed.
+ TS driver Vas got wrong value when fs changed
+ Possible to open .unt files generated in older versions of LspCAD
+ LambdaS (creep factor for Cms) added to list of TS paramters.
LspCAD 6.00 (2004-10-17)
+ USB copy protection dongle operating
+ Wizard for G(s) LP/HP filtrers
+ Color distribution for polar map improved
+ Memory leak fixed.
+ Clipboard cleared when program closed
+ Default TS values set to (almost) zero.
+ Problem with imported files not in same path as project file fixed.
+ A few typos fixed.
发表于 2004-11-6 16:01 |只看该作者
我看等一等再说,
发表于 2004-11-8 13:19 |只看该作者
最新的版本破解已经做出,不过等官方版本稳定后再放出破解。
发表于 2004-11-9 00:12 |只看该作者
同意!感谢!!!
GMT+8, 2026-7-8 08:45 , Processed in 0.108135 second(s), 28 queries .
