查看: 1591|回复: 8
这个声卡是否会使人大吃一惊
发表于 2004-12-30 02:01 |只看该作者 |倒序浏览
比较
严格来讲,QuataFire610不属于声卡,是用于音频工作站的音频接口,在专业音频接口中价格算是比较便宜的,可惜,固件和驱动似乎都有问题
23.03 KB, 下载次数: 213
6.67 KB, 下载次数: 211
6.85 KB, 下载次数: 209
7.23 KB, 下载次数: 202
7.35 KB, 下载次数: 199
7.32 KB, 下载次数: 214
发表于 2004-12-30 02:04 |只看该作者
这个声卡是否会使人大吃一惊
[这个贴子最后由Lafeite在 2004/12/30 02:22am 第 2 次编辑]
RightMark20Audio_1104343797.rar
81.24 KB, 下载次数: 203
QuataFire20610_1104344527.rar
165.16 KB, 下载次数: 207
发表于 2004-12-30 02:15 |只看该作者
这个声卡是否会使人大吃一惊
就是这家伙,1394接口
106.13 KB, 下载次数: 199
117.48 KB, 下载次数: 197
发表于 2004-12-30 11:11 |只看该作者
这个声卡是否会使人大吃一惊
蓝色曲线的声卡也不错呀
evv
发表于 2004-12-30 22:48 |只看该作者
这个声卡是否会使人大吃一惊
工作稳定呀
发表于 2004-12-30 23:02 |只看该作者
这个声卡是否会使人大吃一惊
Lafeite 兄,<可惜,固件和驱动似乎都有问题>,您或朋友用过吗?价格?最近想买个声卡,烦请抽空答复!谢谢
发表于 2005-1-1 02:27 |只看该作者
这个声卡是否会使人大吃一惊
2750元,价格没得说,美日产品没有这个价位,我搞不懂是固件问题还是驱动问题? 原始固件似乎可以,就是控制面板无效,必须用Windows音频控制面板.升级固件和驱动后控制程序1、2通道正常,新的问题是无法识别音频输入设备和大部分输出通道失效,输入控制还是无效但硬件正常,只是无法控制而已,以上是在XP_Pro 2002 SP2 系统下,试了两台电脑,特别做了全新的操作系统.下面是官方给我的回复:
Dear LiuJinghui
It is not possible to return the firmware back to first firmware
Did you try to update the firmware or do you have a Quatafire that has the firmware already updated?
If you have early firmware version of the Q/F and need to update the firmware for use with driver v1.15 or v1.19
The firmware updater can be downloaded from the esi-pro.com website
The firmware update needs to be carried on a desktop PC
With a minimum of Windows XP and Service Pack 1 installed
And the Quatafire is best used with its own PSU
Also please try latest driver v1.19 for the Quatafire
[With driver v1.15 and v1.19 once installed correctly you need to select 8ch out in windows sound preferences]
also you did not say what application you are using for multi channel outputs
You may find that the firmware update did not carryout correctly
It needs to go all the way to 100%
What you may have to do is to update the firmware again or maybe 3-4 times
until it goes all the way. keep an eye on the update bar, it
has to go all the way to 100% somtimes it jumps from 40-50% to 100% and
and may make the interface not work properly.
If you encounter a problem with latest driver
shut down your PC and remove the Q/F
restart your PC and with windows fully on screen  run the driver setup but select to uninstall the drivers
when completed dont continue with the driver setup [cancel it]
then restart the PC [so it clears all]
then run the driver setup again [without the Q/F connected] for the driver you wish to use following the on screen instructions
If you use your PC without the Q/F switched on
when you switched the Q/F on again you may well find that the Q/F control panel
shows faders down
from the drop down menu config click on factory default
this will take a little while to update itself
when done the faders are available for use but input will show muted
so unmute what ones you want to use
[Also please try your Quatafire on a different PC with a different make/model of firewire adapter]
Please let me know your results
Regards
UKSupport
   This document is intended for, and should only be
  read by, those persons to whom it is addressed. Its contents are confidential
  and if you have received this message in error, please notify us immediately
  by email and delete all records of the message from your computer. Any
  form of reproduction, dissemination, copying, disclosure, modification,
  distribution / or publication of this message without our prior written
  consent is strictly prohibited. Neither the author of this message nor their
  employers accept legal responsibility for the contents of the message. Any
  views or opinions presented are solely those of the author.
  unless specifically stated otherwise
   uksupport@esi-pro.com
他们的服务和工作态度很好,热情、周到、高效!
但是上面的回复显然把我当作电脑盲了!!!!!!!!!!!!!!!!
朱丽叶也是他们的产品,不知如何?
希望boxman 能买到更好的声卡!
evv
发表于 2005-1-1 23:40 |只看该作者
这个声卡是否会使人大吃一惊
Lafeite 你好,能帮我用下SpectraLAB和soundcheck软件测下线路入和出频响,10h...100k +-几个db
发表于 2005-1-2 15:13 |只看该作者
这个声卡是否会使人大吃一惊
多谢Lafeite耐心细致的解答,祝您及佳人新春快乐永远舒心! 我也相知道,请多费心啦!
GMT+8, 2026-7-7 03:31 , Processed in 0.110430 second(s), 28 queries .
